Hq usb bios flash tool using the MSI LiveUpdate
hq usb bios flash tool using the MSI LiveUpdate to update drivers in Windows is right option? It can be used to flash the BIOS?
I am not recommending you using the MSI Live Update tool to upgrade yours system bios. Because it is good for updating the drivers not for bios, if you want to flash the bios in windows, you may face many errors but cannot restart the system, try and try again until they successfully flash the bios.
Whitaker Sorg
Hi Berta,
Do not use inappropriate in your computer. Maybe further damage your computer system and you do not use it anytime. Usually it happens in the wrong system updates or incorrect installation system so it is damaged and can not be used yet. The BIOS update is done only technician or know updating the BIOS because they know how to use them and for what they use. You can update your Windows drivers to the website of Microsoft in the way that it does not damage your computer.
