HTC Flyer Tablet above Others
What are the things that make HTC Flyer Tablet better than other tablets?
I want to be sure before I decide to buy one.
The HTC Flyer tablet is small enough for those who would like something compact. It is thicker than an iPad though. The stylus pen for the Flyer has also been widely praised especially when dealing with documents. If you are a photo junkie, you will also be impressed with the 5MP camera and a 1.3 MP front camera both of which produce high quality photos.
The Flyer is joined by the Kindle Fire, which only has 8 hours of battery life as compared to the 10-hour battery life on the Galaxy tab and the iPad; but that will depend on your usage.
It also falls short with a single core processor as compared to the Galaxy and the iPad’s dual core processors, but that doesn’t really affect the performance of the HTC a lot when you are multi-tasking. In the end, you have to decide whether the specs of the HTC tablet will meet your needs or whether it would be better to get a different one.
The HTC Flyer supports networks 2G and 3G and accepts mini-SIM. It was unveiled in February 2011 and released 3 months after, May 2011 but unfortunately this model was discontinued. It measures around 195.4 x 122 x 13.2 millimeters and weighs around 420.8 grams. It has an LCD capacitive touchscreen display with 16M colors at 600 x 1024 pixels screen resolution.
It supports multitouch with HTC Sense UI and 2 sets of touch-sensitive controls that can be used to adjust to portrait or landscape view. It has a 3.5-millimeter jack with Dolby Mobile and SRS sound enhancement. It supports microSD that can be expanded up to 32 GB and internal storage available in capacities 16 and 32 GB running on 1 GB RAM.
It supports Bluetooth 3.0 with A2DP and microUSB 2.0. The primary camera supports 5 megapixels at 2592 Ñ… 1944 pixels resolution with autofocus. It features geo-tagging and can do video recording in 720p. The secondary camera supports 1.3 megapixels. It runs on Android 2.3.3 Gingerbread powered by Qualcomm Snapdragon MSM8255T chipset with 1.5 GHz Scorpion processor and Adreno 205 GPU.
It can be upgraded to Android 3.2 Honeycomb. It supports HTML and Adobe Flash for internet access and also supports Java through Java MIDP emulator. The built-in GPS supports A-GPS. The standby time is up to 1,470 hours and costs around 300 Euros.
Notifications
