HTC-G1, Call summary display problem.
I am using a HTC-G1 handset . Its a nice touch system phone. But I am facing a great problem. Generally when we are in connection then for battery saving the light automatically turn off. And when the call end then the light turn on and show the call duration in call summery. But in G1 when I cut a line I don't understand, because at that time it does not make any sound even does not show call summery. It support Android operating system. Now how can I set the call summery option to see details after call ended.
Answered By 75 points N/A #90128
Hello Mustaf,
The problem with the backlights going off and the ringtones not working for your twin line are caused because of a problem in the phone settings.
For the backlight, you need to access the phone and look for the back light settings and adjust them to 'extended' if you do not need the light to be going off so soon. You should also check if you are using the power saver option and turn it off.
As for the ringtones, that being a phone that accommodates twin sim cards, it should be having settings for the ringtones for the first and second line configured differently, and therefore you will need to check the ringtone settings for the line that does not have a ringing tone when someone calls you and ensure that it is not in the silent mode or the volume for the ringtone has been set too low.
Hope this helps.
__
Regards
Lee Hung
