Htc hd2 arabic script reading problem
I have a HTC hd2 handset. It seems to me that it does not support Arabic script.
Is there any solution that I can read Arabic scripts on my HTC hd2?
Waiting for your suggestions.
Well there is no official Arabic support in HTC HD2 but I think it is available in Europe phones and not US.
But there are ROMs out there which can solve this problem
Following are the links from where you can download the ROMs
I think this will work but if it doesn’t then try the link:
Good Luck
Hi Asheley , I think your problem caused a great hazard to you.
But I have some assisting information to get rid of this problem.
Hope your this information will help you to solve your problem.
Thanks
