HTC One X Camera issues
Amarion Dwayne
HTC (Taiwan based company) introduced its new series of smart phone named “ONE” and HTC One x is one of this series. This phone has 8 MP camera with a dedicated special photography chip. User can also make video at 1080P. Phone has a secondary camera of 1.3 MP. This is a good camera for smart phone.
But recently, some users of Mobilissimo discovered a problem with this phone’s camera.
Problem is that, When user opens camera app, sometimes strange green lines appear on one side of screen, these lines don’t affect the picture quality but it is very disturbing for user to see such lines on a 750$ worth smart phone.
As a solution HTC considered the matter and after analyzing the issue, launched an update OTA 1.28.401.9. HTC claims that this update not only solve the about issue but also fixes date issues of colander and screen glitches.
Some people are saying that this is a hardware issue and cannot be solved by software update. We have to wait to see if the problem solves after update.
Another problem observed by some user is the view finder of One X. But there are no authentic reports about that.
The HTC One X is a 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies. It was unveiled on February 2012 and released 3 months later measuring 134.4 x 69.9 x 8.9 millimeters weighing 130 grams. It uses micro-SIM card and has Super IPS LCD2 capacitive touchscreen display with 16M colors at 720 x 1280 pixels screen resolution.
It supports multi-touch protected by Corning Gorilla Glass featuring HTC Sense UI. It runs on Android 4.0 Ice Cream Sandwich upgradable to Android 4.1.1 Jelly Bean powered by NVIDIA Tegra 3 chipset, 1.5 GHz Quad-Core processor, and ULP GeForce GPU. It doesn’t support microSD. It runs on 1 GB RAM with internal storage available in 16 GB and 32 GB capacities.
The primary camera supports 8 megapixels with autofocus and LED flash featuring HD video and image recording, face and smile detection, and geo-tagging. It supports 1080p video recording at 24 fps with stereo sound rec. and video stabilization. The secondary camera supports 1.3 megapixels and supports 720p video recording.
It has 3.5-millimeter jack featuring Beats Audio and Active noise cancellation with dedicated mic; Wi-Fi 802.11 a/b/g/n with Wi-Fi Direct, DLNA, and hotspot support; Bluetooth 4.0 with A2DP and aptX support; GPS with A-GPS support; NFC; stereo FM radio with RDS support; and microUSB 2.0 with MHL TV-out. It has built-in accelerometer, proximity, gyro, and compass sensors. The pre-installed web browser supports HTML with Adobe Flash support.
Java is not supported. It runs on non-removable Li-Po 1800 mAh battery and available in gray and white colors. If you have a problem with the camera, try to factory reset your phone. On your phone, go to “Settings,” “Storage,” “Factory data reset,” “Reset Phone,” and then “Erase Everything.” Your device will then perform a little housekeeping and wait until it is complete.
If there is no problem with the camera physically, restoring the default firmware should fix the problem. But if this doesn’t work, try bringing it to an HTC service center for proper servicing. Note: before doing factory reset, backup your phone’s data first.
Notifications
