HTML code appears whenever I try to access the User Account applet
Asked By 250 points N/A Posted on -
I have a Windows XP machine on my Laptop. I week ago I Access User Account applet to add more users for my brother and sisters add some pictures and their desired password for each account. I Have created a total of 4 accounts with password.
I try to login each account and everything was fine.
Recently my sister forgot her password and wont able to login to her account. We try any possible combination but failed in the end. So I decided to just delete the account I’ve created and create a new.
Again I open the User Account applet but an error appears. Whenever I attempt to open the User Account applet in the Control panel the User dialog pops up, but the page is empty or filled with raw HTML code. Also, the menu option is missing sometimes.
The raw HTML code the appears whenever I try to access the User Account applet
Best Answer by Riley weaver
Answered By 0 points N/A #108106
Hi
Hope you will be fine ,here i am sending resolution of your this account ,
this issue is due to Windows explore .exe file , in registry
Just hold Ctrl+Alt+Del keys combination and Windows Task Manager will appear ,Click in File menu New Task option will appear click this option Create New Task window will appear type here Explorer.exe, your all desktop profile will appear .
Hope to resolve your issue with this helping command task.
Engineer
Answered By 10 points N/A #108107
Hello Alieen,
As far I have seen your error in here, it shows that you have some javascript codes in here. Now first ensure that you’re all the codes are perfect and then be sure that all the tags are also ok. Now found a convenient result that is pretty simple. Download VBScript named useraccfix.vbs. Now run this program by double clicking on it. And it will show a pop up box and it will show that “ it fixed the HTA settings”.
I hope it will be ok if my assumption about your problem is right.
Thank you,
Riley weaver.
