Hello fellows,
How to put some smiles dark background? I want a smiles dark background for my html project to be submitted next two weeks. I am still on the planning process and need some help from you. Can you provide some tutorial information that will probably help me a lot?
Christine Turner.
HTML Codes for Inserting Emoticons with Black Background
You need to know few things before adding the background smiley picture. Actually I am telling you to how to add an image to the background. If you want to add smiley then it should be a gif file. So you can also add a gif file using this code. Make sure when you selected an image, please find the resolution of that image. If it is very large, convert it to small.
This is a very simple code. It has given below.
<div style=”background-image: url ( /pic / smiley.gif) >
In the above code, there is a URL. In that URL you have to give the path of your smiley picture.
If you want to change the resolution, use this code.
<div style=”background-image : url ( /pic / smiley.gif);
Background-repeat: repeat;
width:150px;
height:150px;”>
That’s all. If you want to know more about this. Please refer the link that I have given below.
https://www.quackit.com/html/codes/html_background_codes.cfm
