Html editing software for intranet free website
Hello expert, I need to convert front page intranet to HTML editor and also I need to edit it. Please can you send me a html editing software for intranet website. Where can I get it for free?
Hi there,
Create a browser window and follow the steps:
Use the Open File … from the File menu to find and open the HTML file you want to edit. Re-open your text editor. In the editor, open the file and make changes désirés.Notez that this text should be above tags </ body> and </ html> at the bottom of your HTML file. Select Save from the File menu to update the changes in your HTML.Ensuite to reload this document in your Web browser, go back to the workspace where the previous version of your file was posted. Note that the new text that you entered in the steps that we have seen is perhaps not yet visible. To see these changes, use the button or menu item Reload your browser. Note that the browser ignores any blank lines and extra spaces you type in the HTML file. It will also ignore all characters in space too.
Notifications
