HTML for a static gallery.
HTML can create higher customizable static gallery pages with thumbnails and direct links to actual photos prepared for net publishing.
HTML can rapidly produce photo albums that could be uploaded for the internet to be noticed by buddies and loved ones .
you can find attributes for labeling and captioning images and photo collections.
Also, subsequent and preceding links are developed.
Hi Manir,
Static Gallery is a set of pictures published on the website to show your slideshow without reflecting any dynamic changes basis time.
We can create such static Gallery with the help of static HTML tags as expressed following.
Define images with the <img> tag.
The <img> tag is empty, which means that it contains attributes only, and has no closing tag.
In order to display an image on a page, we need to use the src attribute. Src stands for "source". The value of the src attribute is the URL of the static image that is in need to get displayed.
The syntax for defining an image:
<Img src="url" alt="some_text">
Read more below to the following link.
https://www.w3schools.com/html/html_images.asp
Hope this helps.
Thanks
Baker
Notifications
