HTML Style for transparent text areas?
I am looking for an HTML code that can allow me to make a text area with a given size from which I can be able to scroll up and down. And the background image should be visible behind the text so the text area opacity should be adjusted to do this. How can I achieve this? Kindly please help me.
Answered By 0 points N/A #161186
You can easily set the text boxes transparency. First you have to create a “div element” with height , width and a background image which you want to see. Then create another “div element” inside the first “div element”. Now set the inner “div element’s” class to “transbox”. Now you can add text in the transparent div. Here’s a sample code:
<html>
<head>
<style>
div.background
   //add here height, width and background
div.transbox
   //edit your transbox
div.transbox p
//edit the format of texts you want to use in the text box
</style>
</head>
<body>
<div class="background">
<div class="transbox">
<p> text  show </p>
</div>
</div>
