lance faz
Posted on - 05/25/2013
Hello guys!
I'm currently making my own website. I would like to put an add picture command to it but I can't seem to do it. I guess there's something wrong with html codes I'm using. Do you know any html templates for this?
Please help me. Thanks!
Html templates for add picture command
There a number of HTML codes that you can use to add pictures to your website. From this site you can get a number of HTML picture codes that relate to your website and even get guidance on how to go about picture HTML codes, which are very important and appealing factors on any website.
    As you are trying to put the function that can add picture on your web-site so there is a little lack of knowledge here.
You didn't say that either you wanted to add the add picture button only or you wanted to add the function in the page.
If you want to add this function then you'll be needing to use PHP also along with the HTML so the implementation will be fine!
Please check this link for visual insertion only!
Hope you got your answer! In case you still have any queries please ask again! 🙂
