While running any .NET application I faced the following error. It is severe in the cases of .NET Application IIS7.
I need to fix it up.
HTTP 404.17 – Not Found. The requested contenet appears to be script and will not be served by tge static file folder.
HTTP 404.17 – Not Found, Error Code: 0x80070032
Dear Heather Abreu,
This error arises mainly when you have an error in your .Net framework, which can cause many applications to hang and even cause data to be lost.
You should run a System Restore for a previous setting which was effective, in case you have activated the System Restore option, or, you can update your .Net framework with the latest one.
You can find it in the following site:
http://www.microsoft.com/en-eg/download/details.aspx?id=17718
Hope these two solutions were helpful.
Best regards,
Don Muench
