HTTP 500 Server Error in VDE
Hello all!
After many attempt, CuteFTP had errors–I had to upload "/lists" piecemeal;I think I have "config.php" right now; I disabled the "magic_quotes" line with "#"–the host runs CGI and NOT Apache)
But I still found HTTP Error 500 Server Error.
After that I got the message about using CHMOD to set permission 644. After spending a long session with my hosting service, I have twitched “web/lists” to make permission that my host can give. I don’t found any change in HTTP Error 500. I have found this message in the hosting service:
“The command chmod doesn't work because our system uses the Virtual Dedicated Environment (VDE) instead of a pure UNIX® system”.
Is it informing that phpList can’t operate in this hosting?
Possible help needed. Thanks.
