Sir, I am not from a computer science background and know little technical things, now I am getting error code 304 every time I tried to use some links. Can you please tell me why is it happening?
HTTP Error Code 304 Generated While Using HTTP Web Request Page
First of all check when every time you get error code 307 in a web browser, you should be redirected to some alternative URL if in case you are not redirected then either the web server software you are using is itself defective ,or the webmaster has not done the URL redirection settings correctly. So if you are redirected to another one then that one will redirect back to the original URL .So all you have to do is to just retry the alternative URL.
