Brian Tony
Posted on - 10/10/2011
HI,
I am facing the following error after installing apache into my system. It was not present before the apache installed.
So I guess it is for that program.
But I don’t have idea that how to solve it. Should I upgrade any program?
Please let me know the solution.
httpd.exe – Application Error
The instruction at "0x2808625D" referenced memory at "0x13715268". The memory could not be "read".
Click on OK to terminate the program
Take care.
Tony
Httpd.exe – Application Error .
The data that is loaded on that particular memory address cannot be accessed. It is maybe due to a failing RAM memory card or in the disk cache or in the file accessing the cache. If you can use other programs on your computer then there would be no problem with the installed RAM memory card.
Try uninstalling and reinstalling the program if it might fix the problem. You may also want doing a disk check on your hard drive to check your hard drive for errors. If you have other disk utility program use it to check your hard disk. Here’s how you can do a disk check on your disk using Windows’ default checkdisk:
Right click drive C and then click Properties.
Click Tools tab.
Click Check Now button.
Check Automatically fix file system errors and then click Start.
After the disk check if it didn’t find any problem, obtain other copy of the Apache’s installer since the error appeared after installing the program.
