Huawei Ascend G 300 features Pocket-lint
Hi Mr. Braxton Fredrick,
This is base on my research according to the user review,
Huawei Ascend G300 Specifications:
GENERAL
2G Network GSM 850 / 900 / 1800 / 1900
3G Network HSDPA 900 / 2100
BODY
Dimensions 122.5 x 63 x 10.5 mm
Weight 140 g
– Touch-sensitive controls
DISPLAY
Type TFT capacitive touchscreen, 16M colors
Size 480 x 800 pixels, 4.0 inches (~233 ppi pixel density)
Multitouch – Yes
**The Huawei Ascend G300 has a 4 inch screen, which is 11.7% more than the average for all Smartphones. In addition, the Huawei Ascend G300's is equipped with following display features: Ambient Light Sensor, Multi Touch and Proximity Sensor
SOUND
Alert types Vibration, MP3 ringtones
Loudspeaker Yes
3.5mm jack Yes
MEMORY Card slot microSD, up to 32 GB
Internal 2.5 GB storage
DATA
GPRS Yes
EDGE Yes
Speed HSDPA, 7.2 Mbps; HSUPA, 5.76 Mbps
WLAN Wi-Fi 802.11 b/g/n, Wi-Fi Direct, Wi-Fi hotspot
Bluetooth Yes, with A2DP
USB Yes, microUSB v2.0
CAMERA
Primary 5 MP, 2592Ñ…1944 pixels, autofocus, LED flash
Features Geo-tagging
Video Yes
Secondary -No
**The Huawei Ascend G300 is equipped with a 5 megapixels digital camera, which is slightly worse than the average for all Smartphones. This smartphone's camera is also equipped with Autofocus, LED Flash and Video Recording.
FEATURES OS Android OS, v2.3 (Gingerbread)
Sensors Accelerometer, proximity, compass
Messaging SMS(threaded view), MMS, Email, Push Mail, IM
Browser HTML
Radio Stereo FM radio with RDS
GPS Yes, with A-GPS support
Java Yes, via Java MIDP emulator
Colors Black, Silver
– SNS integration
– MP3/WAV/eAAC+ player
– MP4/H.263/H.264 player
– Organizer
– Document viewer
– Photo viewer/editor
– Voice memo/dial
– Predictive text input
BATTERY Standard battery, Li-Ion
Technical Specifications
**The Ascend G300 is aimed at the lower end of the mobile market and packs a single-core 1GHz processor, 512MB of RAM, 4-inch WVGA touch screen, 5MP camera, Android 2.3.6 Gingerbread.
The Ascend G300 is the first Huawei handset to features the Chinese firm's new Android overlay, known as Huawei Android Platform 5.1 (or HAP 5.1 for short).
Hope this help,
