Huawei honor in the Indian market
Huawei has been officially landed on the Indian market along with an updated series of Ideos X5, does this phone's have a reliable battery life and does overheating issues?
Hi Vicky Dodson
Huawei ideos series is really a affordable series. Users can enjoy Android featured phones at low cost. This is very charming especially for Asian markets. But reduction in cost comes with some compromise, Same is the case with Huawei ideos X5. Hardware wise it is not best quality phone. With its single core processor and 2 Mp camera its battery is 1500mAh. This battery power is quite low for an Android phone. Battery of X5 drains very quickly even when at stand by mod. Practically talk time is quite low and overheating is also observed during continuous use. But the problem is not so big to avoid the phone especially when you are short of money.
There are some ways to optimize the battery timing. Always keep your screen resolution at low levels, turn off WIFi after use, keep your 3G mod off when not in use, minimize the use of network data. Above said precaution can help to improve battery time and any overheating.
Next model Ideos S7 is with 2200mAh battery and expected to have improved battery life. So if you can afford then think about Ideos S7.
I hope it will be helpful
Regards.
If you are planning to buy a Huawei Ideos X5 Smartphone, check out these specifications. The Huawei U8800 Ideos X5 Smartphone is a 3G device operating on 2G and 3G bands using GSM and HSPA technologies. The handset was announced on December 2010 and released on April 2011. It measures 120 x 62 x 11.6 millimeters and weighs 130 grams.
It uses a mini-SIM card. It has a TFT capacitive touchscreen display with 16M colors at 480 x 800 pixels screen resolution. It supports multi-touch and protected by scratch-resistant glass with oleophobic coating. It runs on Android 2.2 Froyo upgradable to version 2.3 Gingerbread powered by Qualcomm MSM7230 chipset, 800 MHz Scorpion processor, and Adreno 205 GPU. It supports microSD expandable up to 32 GB.
It runs on 512 MB RAM with two 4 GB internal storages. The primary camera supports 5 megapixels at 2592 х 1944 pixels with LED flash and autofocus. The camera features geo-tagging. The camera can record video in 720p at 30 fps. It doesn’t have a secondary camera. It has Wi-Fi 802.11 b/g/n with hotspot, Bluetooth 2.1 with A2DP and EDR, GPS with A-GPS, and microUSB 2.0.
The Huawei U8800 Ideos X5 handset has built-in compass, proximity, and accelerometer sensors. The pre-installed web browser supports HTML with Adobe Flash. It supports Java. It runs on Li-Po 1500 mAh battery with standby time up to 380 hours on 2G and 440 hours on 3G. Talk time is up to 8 hours 20 minutes on 2G and 6 hours and 40 minutes on 3G.
Notifications
