The Huawei P8lite Smartphones And Huawei P8max Phones
What are the common vital features which lie between the Huawei P8lite smartphones and Huawei P8max smartphones not forgetting the distinct features surrounding both smartphones? In terms of screen resolution which of these two fall ahead and considering battery life duration and general performance? My name is Maxwell Jacobs from Nigeria. Thank you.
Answered By 0 points N/A #148860
The two phones share a lot in common such as the camera and run on the same android version platform 5.0.2. The P8lite has a 5 inch screen with pixel density at 294 with the resolution being 720*1280. The phone runs on an octa-core processor and has a 16GB internal memory and a ram of 2GB. The battery capacity is 2200 amps. The Huawei P8Max is a 6.8 inch smartphone with a resolution of 1080*1920 and a pixel density of 326. The P*max has an internal memory of 64GB and a ram of 3GB. The phablet runs on a quad-core processor. It has a battery capacity of 4360 amps.
The screen resolution and the battery go to the P8max, while the performance goes to the P8lite.You can have a detailed review of the Huawei P8Lite and the Huawei P8Max
