HUDWAY APP when can we download?
I just heard from a friend that HUDWAY APP is available for iPHONE and its used as a navigator in your CAR
Can anyone give me complete details on the devices it works?
Cost if any
Step by step method to use it
Best Answer by Aron Hank
Answered By 0 points N/A #199035
HUDWAY is an App designed to increase the safety of driver while driving. It provides you directions in low visibility conditions. It does not require constant internet connection, provided the routes are preloaded. You just need to download the app from the app store or iTunes, provide the destination and it gives you the directions. It does not require any other system along with it.
The App is available in Apple Store and iTunes for free. The Android version of the App would be available in Feb, 2014.
Answered By 0 points N/A #199037
It will come in Androids this February 2014, but for now only iOS users can simply install the app on their device, program the route and then set it on your car’s dashboard and should be facing up for it to display the GPS info on the windshield of your car.You can download it free from the App Store and it is already available for iOS iPhone. Meet Android version by Feb 2014.
