davionevan
Posted on - 07/30/2013
Hello Techyv Friends, Is there any kind of filter or even software to make huge eps batch for translation.
Currently I am using Trados, which handle the Framemaker files very easily.
The main issue is to find a way to translate EPS files without handling them one by one. Thanks
Huge eps batch for translation
I don't know if you have heard this tool but this can read up to 100 image formats including eps. This means you don't have to manually translate each image and manually handle one by one like the one you used today.
This tool also allows EPS to various image format translation or vice versa.
The software is called batch photo which you can download here.
