Hulu videos could be stream outside United States
Hi all,
I live outside United States. Whenever I try to load a video from Hulu.com, the following message appears:
We’re sorry; currently our video library can only be streamed within the United States.
For more information on Hulu’s international availability, click here. If you’re inside the United States and believe you have received this message in error, please click here.
Here is a picture to better describe my problem…
Please Help.
Best Answer by Obasu
Answered By 0 points N/A #82517
Hello Kyle Lee my name is Joyce!
Videos on Hulu.com could really not be viewed outside the United States. Unless of course you know how to do anonymous surfing. It is a bit tricky though but you'll get the hang of it once you know the different processes.
  • 1. You may access Hulu.com outside US through Proxy servers with US IP address. Let me share to you two of the circumventors:
www.secure-tunnel.com
  • 2. You may use VPN. You must know a US based server. VPN will be your virtual tunnel so you can access Hulu.com. You may use Indentity Cloaker which offers private networking through an OpenVPN client.
How to use it?
  1. Start the OpenVPN client and you should see a small computer icon on the taskbar.
  2. Right click it.
  3. Select on the nearest US server to you.
Note: you would need to subscribe for it in order for you to use it.
Answered By 30 points N/A #82518
Dear,
For watching movies on Hulu.com, you must living in United States. Because that site only allow US visitors. When we try to load any video, site server read our IP address, if our IP address not belongs to US IP range; server denied our request and show that error message.
For overcome this issue, you should change your IP address according to US IP addresses. Here is some example of US IP addresses:
  •     12.47.144.64 – 12.47.144.87
  •     12.47.144.96 – 12.48.144.191
  •     12.48.144.200 – 12.63.178.59
  •     12.63.178.64 – 12.68.117.71
  •     12.68.117.80 – 12.70.153.31
  •     12.70.153.40 – 12.70.153.47
  •     12.70.153.72 – 12.106.65.79
For changing your IP address, you can download IP changer software. This software changes your IP address and when you open Hulu.com, that site allows you as US visitor.
You can obtain this software from website  Help and using detail of said software are available on that site.
 Cheers
