Humax having problem connecting to the server
Hello Guys,
I would like to share a difficulty of mine which is basically a problem with connecting to Humax using network in OSX. Whenever I try to go to my HDR-FOX T2 via the system using OS X Lion, I get the below error notification:
There was a probIern connecting to the server "humax"
The version of the server you are trying to connect to is not supported. Please sontact your system administrator to resolve the problem.
OK
I faced a problem linking to the hosting server “humax”. “The version of the server you are trying to connect to is not supported. Please contact your system administrator to restore the problem." It always shows the same mistake whether I only try and look through to it, or "Connect As". I presently have the samba 2.2.12-3 program set up, and as you can see that in the sidebar of the box is showing in the program products as "humax". I can FTP in except facing any difficulty, but it would be useful to just get to it immediate via the OS. If any of you have any experience about such situations, I would request to share the solution, also any idea about what kind of problem is this?
