kristan lai
30 points
Posted on - 05/09/2012
I have a Windows 7 Ultimate x86 in Hungarian Language. On it is a CD burner XP pro 4.2.7.1849 (latest version with Hungarian Language) I run it as the administrator but an error message always pops up even when I did nothing at all. I'd like to know if the error can be fixed? Also, is it possible to change the order of the files before burning them into the disc? Because I would like to save the files in alphabetical order. Your help on this matter would be a great help to my needs. Thank you so much for the assistance.
Hungarian CD burner XP pro 4.2.7.1849 error
This types of problem happened some time, however you do not have to worry. The error is fixable, all you have to do is follow the steps and your system should be fine:
This error is occurring because you do not have permission to write on that specific registry key.
– Go to the start menu, click on the run button and then type the word “regedit”.
– Find out the defected key which creating problem.(Just follow the error message)
– Go to “edit” and then click on the “permission”.
– All you have to do is add your current user name in the permission box and check “allow all” to get full permission.
