Hw to fix Windows 7 registry MSI corruption
I have brought Windows 7 and is using the same, I need to know about how to fix Windows 7 registry MSI corruption related issues, please do let me know about how to get it solved online. Please help me.
This is a problem that you can fix it very easy and in a short time with the tool that you will find on Microsoft website. This tool  is named Fix it . Download and install this tool on your computer and your problem will be fixed by this program automatically without any effort for you.
Tweaking the window registry is good for keeping it fast and error free. Here is small software link which is best for fixing the window registry errors and it is also best for removing temporary files etc. Here is another link for same software. If you are internet user then you have to run it monthly or as you feel system going to slow down. Hope this is very helpful.
