HyCam2 cannot be opened after the installation
Hi there,
I just installed on my PC HyCam2 and when I tried to open the program this error appeared on my desktop. I didn’t find this missing DLL file on the Internet and now I cannot use my webcam. Can anyone help me please to fix this error ?
Thank you !
HyCam2.exe – Unable To Locate Component
This application has failed to start because MClick2.dll was not found. Re-install the application may fix this problem,
Answered By 590495 points N/A #179162
Check if you meet all the requirements. One possible cause of a missing DLL file in an application is incompatibility. So make sure your operating system is supported. Since there is a missing DLL file on your application then you should reinstall it. See if this fixes the problem. If the same error appears again, try searching for the missing DLL file on your drive.
Once you found it, copy it to “C:WINDOWSsystem32” then register it. Click Start, Run then type without quotes “cmd” and then hit Enter. In the command prompt, type without quotes “regsvr32 mclick2.dll” then hit Enter. Close the command prompt then restart the computer. Start HyperCam then see if it works. By the way, the executable indicated in the dialog box “hycam2.exe” is the main executable of the HyperCam software.
If the problem continues, try downloading the installer again from the official website. Download HyperCam 2.29. It requires Windows 2000, Windows XP, Windows Vista, Windows 7, and Windows 8.
