Hyper Terminalnull modem Hyper Terminal error
I just got my Sun box from eBay with Solaris but now I am unable to connect via Hyper Terminal to Solaris which cannot properly boot up. I have spent so many hours to fix this problem but I could not resolve this issue.
You can see the attached error image below so please provide helpful solution.
Any help would be greatly appreciated.
Checking Memory: done Press spacebar to enter ROM mode Booting default method – From settings First stage kernel (Linux) : Decompressing – done ERROR: cannot relocate with filesize 0 Second stage kernel: Decompressing
HyperTerminalnull_modem – HyperTerminal
Answered By 0 points N/A #171247
First of all you have to suggest what kind of a cable and hyper terminal settings that you are going to need.
Before making cable and hyper terminal settings you must make sure that you have not plugged  at the same time that you want to use the serial port.
Cable setting would be as following.
25 male to 9m/f
In 25
25      pin2      pin3      pin7
9        pin3      pin2      pin4
Pin 2 is transmit
Pin 3 is recieved
Pin7 is request to send signals
Hyper terminal settings would be 38400
                                                              8
                                                               N
                                                              1 for hardware
