Hyperic and AutoScan-Network in terms of network management
Kindly advice how  effective are Hyperic and AutoScan-Network in network management. Can somebody here give me a brief description of what in particular they can do in managing a network and what are the additional features that make these applications highly-efficient. Thank you.
Answered By 15 points N/A #105942
Hyperic and Auto Scan-Network in network management software is a very effective software for any computer or laptop when you are connect with a local network.
If you use that software in your computer, then you can manage your computer and you can manage others computers too which is already connected with local area connection. You can easily scan computer and you can check how much bandwidth used and you can check the network speed and various kinds of network related features from that Hyperic and Auto Scan-Network in network management software.
This software or application mainly works for exploring your windows network.
Thanks
