I Am Facing 0xcaa30194 Error While Signing-in To The Office 365
Write about the 0xcaa30194 error? Explain the error code briefly and show the steps to fix this error code and add the snapshot of the error?
Sign-in error called a 0xcaa30194 error that occurs when the user tries to log-in to Office 365. The most significant cause of the occurrence of the error is the bad internet connection. There are mainly two solutions for the error code and that is described as follows:
Solution 1:
Access the registry path and re-assign the values.
Step 1: Access the registry path as directed below:
Computer \ HKEY_CURRENT_USER \ Software \ Microsoft \ Office \ 16.0 \ Common \ Identity
Step 2: Add the new value of type REG_DWORD with the name EnableADAL with value 0.
Step 3: Remove all DisableADALaptopWAMOverride entry if it exists.
Step 4: A pop-up window will appear after restarting the system.
Solution 2:
Restore the system to previously configured settings.
