I Am Facing A 0xc004f074 Error While Activation Of The PRO Key Of The KMS
Write about the 0xc004f074 error? Explain the error code briefly and show the steps to fix this error code, and add the snapshot of the error?
When the user tries to upgrade to the new Windows, then the error 0xc004f074 displays. Windows is unable to reach the company’s activation service. 0xc004f074 error code indicates that the Key Management Service cannot be contracted during the activation procedure. The methods to fix the 0xc004f074 error code are as follows:
Change the Key using the activation wizard.
Step 1: Hold Windows Key+ R and type ‘slui 4’ then press Enter.
Step 2: Now, hold Windows Key+ S to open settings.
Step 3: Select Update & security and click on Activation.
Step 4: The user will receive an option Activate by phone.
Step 5: Start the Product Activation Wizard.
Step 6: Open the charms menu and select Settings.
Step 7: Go to Change PC Settings and click on Activate Windows.
Restart the system and perform your task.
Notifications
