I Am Facing An 800ccc0e Error While Communicating Through Emails
Write about the 800ccc0e error? Explain the error code briefly, and show the steps to fix this error code, and add the snapshot of the error?
The error 800ccc0e is probably the most common error that MS Outlook or similar email client users face while performing the email communication. The error message displays, ‘The connection to the server has failed. Account: ‘your_account’, Server: ‘your_SMTP_server’, Protocol: SMTP, Port: 25, Secure (SSL): NO, Socket error: 10061, Error Number: 800ccc0e.’
Internet connectivity, Antivirus settings, Windows firewall, SMTP authentication error are the possible reason behind the occurrence of the error. The method to resolve the error code is as follows:
Method 1:
Check Internet Connection.
Reset the internet connection.
Method 2:
Clean all the messages stuck in Outbox.
• Select the Work Offline mode under the Send/Receive tab.
• Select the outbox folder, move the messages to the Draft folder, or delete the messages stored in the Outbox folder.
Method 3:
Increase server timeout setting
Step 1: Launch Outlook.
Step 2: Go to File >> Info >> Account Settings.
Step 3: Select the target account and click on Change.
Step 4: Select More Settings and click on the Advanced tab.
Step 5: Increase server timeout settings.
