I Am Facing An 800f0831 Error After Installing Windows
What is the 800f0831 error? Explain the error code briefly and show the steps to fix this error code, and add the snapshot of the error.
800f0831 error is an update error that occurs when the update install detects that the system firmware or device isn’t up to date. The cause of the error is improperly configured or corrupted system drivers, damaged or virus-infected Windows registry, corrupted system files, and conflicts in system drivers. The steps to troubleshoot this error code are as follows:
Step 1: Open the command terminal by pressing Windows Key + X.
Step 2: Select Command Prompt (Admin).
Step 3: Run the following commands in the prompt:
net stop wuauserv
net stop cryptSvc
net stop bits
net stop msiserver
ren C:\Windows\SoftwareDistribution
SoftwareDistribution.old
Ren C:\Windows\System32\catroot2
Catroot.old
net start wuauserv
net start cryptSvc
net start bits
net start msiserver
pause
Step 4: Exit the command prompt and check it works or not.
Notifications
