I am facing a big problem with my recently bought a laptop.
I am facing a big problem with my recently bought a laptop. I am not able to login to WPA2- Protected Enterprise Wi-Fi. It’s an eduroam network of my university, which runs well on radius servers … I'm using Windows 7 and in spite of correct settings for username and password every time a network authentication error occurs. My Google search was also unsuccessful.
I expect that probably I did not stand there with the problem alone. If any one of you might even come across the same problem and yet has found a solution? Drivers and so on are up to date, and I am confident that I have configured the wireless network works properly (I worked around it many settings which managed but everything failed). The wireless works perfectly I was able to latch onto unsecured networks, but this story WPA2-Enterprise is reluctant.
Thanks in advance.
