Jamin Ywain
60 points
Posted on - 12/17/2012
Hello Everybody,
I like to listen to instrumental music in my system. But I am not able to listen for 1 week as I am facing an error with my media player. It says that license is already installed. Now, I am planning to purchase a new computer as the mother board and RAM are to be upgraded.
I want the experts to tell me whether all my default settings will be affected or will they remain same.
Please confirm me soon so that I can go for new computer up gradation.
Thank you very much.
As I am facing an error with my media player
Hi there user:
Did you try to install different types of Media Player in your unit? There’s a lot of Media Player which are downloadable on-line. I suggest you get one (1) and install it to your unit. These Media Players don’t require higher specs anyway. https://en.softonic.com/s/all-types-of-media-player.
There will be minor changes to the settings if you upgrade, take your time to set-up. But what's important here are your files. Make sure you back-up your important files before you upgrade.
Thanks for posting here at techyv.com
Best regards,
