I am facing an issue with F-Secure 2012
I am facing an issue with F-Secure 2012 edition as “The setup.exe program is truncated when downloading.
C:Transfersetup.exe
C:Transfersetup.exe is not a valid Win32 application.
Regardless of the above mentioned scenario, Unity 3D Editor gets installed quite smoothly over my Windows 7 64-Bit Version. But it comes to get started with, eventually it stops working. However, there is an alternate way to get rid of this issue using the same 64-Bit platform.
Unity Editor has stopped working.
Windows can check online for a solution to the problem.
Check online for a solution and close the program
Close the program
View problem details
