I am facing the subsequent problem during the execution of C++ program:
Debug Assertion Failed,
Program: …My DocumentsVisual Studio 2008ProjectsCodeDebugCode.exe
File: f:addvctoolscrt_bldself_x86crtfeoferr.c
Line: 44
Expression: (stream! = NULL)
I really don’t have any idea how to get fix it. Please, help on me this issue.
Best Answer by Vaishnav Simmons
Answered By 5 points N/A #137149
Actually, you can’t fix this. Because this bug message means that some condition is not expected. But if you want to solve this go back to whatever gave it to you. When you can’t recognize its cause go to this page:
https://docs.microsoft.com/en-us/sysinternals/
It may help you and no need to install. run this when the dialog above is displayed. Then, in your toolbar, look for the button that looks like target. Put the error message and they will give the cause to you.
Hope it will help you.
Answered By 10 points N/A #137150
This is a programming error and if you writing a program and after compilation you are getting this error message then you have to look your code at line number 44 see for any programming error and fix them to execute program.
Smith Thompson
