I Am Facing Sudden Windows Failure
Yes, you can recover from Complete Windows Failure. You have to relax if your OS simply refuses to boot. You must know that many laptop manufacturers pre-load their portables with a recovery partition on the hard drive itself. The partition is mandatorily designed to load the version of Windows bundled software. In case of an emergency, hitting one of your laptop’s function keys during boot up typically launches this feature. Also tapping F11 on Lenovo Think pads activate its Recovery Program, while it’s F12 for Dell machines.
Be aware that taking this route will wipe the laptop’s hard drive, might also result in lost data. Fortunately, these recovery tools also offer various ways to repair the current installation of Windows. Another way to repair your Windows is by booting the laptop from a system repair disc (CD) which you can create. In Windows 7, click Start > Control Panel>System and Maintenance> Backup and Restore. On the left side of the screen, you will see the option to create a system repair disc. You might be required to insert your Windows installation disc into the CPU during this process.
