Ywain Jamin
Posted on - 05/02/2021
What is the 0x0000000d1 error? Describe the reason for this error and explain various steps to fix the error?
I Am Getting A 0x0000000d1 Error While Working On The System. Guide Me To Fix The Issue.
Corrupted operating system files in the Windows Operating System cause a 0x0000000d1 error. It is a common BSOD error message. Apart from misconfigured Windows Files, this error can be due to a Windows upgrade or because of some change that occurred in your hardware.
The way to fix this error is to install tech utility repair tools and scan then fix the problems using the tool; and other ways to fix the error are as follows:
- Insert windows ten bootable DVD and restart the system.
- When prompted, press any key to continue.
- Select your language and click on Next, then click on the Repair option.
- Click on the Troubleshoot option.
- Click on the Advanced option.
- Last, Choose Automatic Repair.
- Wait for the completion of the process and restart the computer.
- Run System File Checker and Check Disk
- Repeat the above process but now click on Command Prompt in the Advanced option.
- Type the given command:
Sfc /scannow /offbootdir=c:\ /offwindir=c:\windows chkdsk c:/ r
- Run the command and restart the system.
