I Am Getting A 0xc000000f Error Code On Booting The Acer Laptop
Outdated device driver, Connection issue, Windows not updated, Misconfigured settings, Corrupted or damaged hard disk, and the DVD connected might be faulted are some of the reasons for the 0xc000000f error code. The solutions to fix the error code are as follows:
Solution 1: Removal of Devices and USB Connected to PC
Plug out all the external devices from the computer and then boot the system.
Solution 2: Use Set up wizard to repair the computer
Step 1: The user needs to insert in the DVD then choose the Language to install, Time and Currency Format, and Keyboard Input Method.
Step 2: Click on the Next and select the Repair option.
Step 3: After performing the process of completion, restart the system and perform your task.
