I Am Getting CMOS Checksum Bad Default Configuration Used. Show Me Its Solution.
What is a CMOS checksum bad default configuration error? Describe the reason for the error and explain various steps to troubleshoot the error?
There are mainly a few reasons for the error-
Follow the steps given below to solve this problem:
Method 1. BIOS change/semiconductor (CMOS) to complementary metal-oxide setting can cause serious problems, and it can prevent your device from starting properly. Microsoft cannot guarantee that problems causing by BIOS/CMOS setting can be solved. Changes to settings are at your risk.
If your PC constantly shows errors about clock or CMOS while starting PC, the CMOS battery on the motherboard maybe needs to be replaced.
