I Am Getting Error Message On My iPhone
I can't send a message on my iPhone.
It's popping out a message: Error sending message.
The odd thing is that i can place a phone call.
How can I resolve this?
If you can not send a text message from your iPhone, but you can make an outgoing call, try turning off your phone and then remove its battery from the battery compartment. Keep it that way for a couple of minutes then attach it back to the phone then turn it back on. Try sending a text message again when the phone fully starts.
If you still can not send a message even after doing this, try updating your phone’s iOS software. If you are sending your text message to multiple recipients and you enter their respective numbers manually, be sure to tap return instead of placing a space between the numbers to separate them.
