I am trying to install MAX version 4.7.7.f0 but I am getting an error message. I have tried to uninstall then install NI developer suite 2011 but the error is still there. The exact error message would say:
"SR-03-000-cpu (10.5.2.123)
The selected system does not support this function"
Thank you very much for the help.
I am getting an error when installing MAX version 4.7.7.f0
You did not actually say the last operation that you did before this error happened. Maybe that command triggered this error because the task you started is not supported on your computer’s current configuration.
Maybe the operation requires another device to be installed for it to work. If you are not sure, try restarting your computer and then try it again.
If it still fails, try doing a clean installation of the program again to clear your system from any corrupted files. Uninstall MAX from your machine then restart your computer. After booting the system, check your computer for any possible errors.
Use a disk utility application to check the system. Install the application again after the disk check and then restart what you are doing.
