I am getting errors using MOSS 2007 form generator.
Hallo.
I have posted this question on several forums but I have not found an answer to it. I have been using MOSS 2007 form generator, but at some point I started getting error 6482 on the server which is recurring after every few seconds. What is the cause of this error and how can I go about fixing it? Thanks a lot for your prompt response.
Answered By 0 points N/A #159666
Did you try if the SharePoint server search is working? Please check your search setting because it is possible that the search index is damaged, deleted or corrupt .Try clearing the search cache. If the SharePoint server search is also getting the same error, 6482 error, try uninstalling then reinstalling the SharePoint Search Service. To help you more, try visiting this link:
https://technet.microsoft.com/en-us/library/cc262700(office.12).aspx
