I am getting the following error message when using Drive Image XML
Hello everyone,
I wonder if anyone could aid me in solving this problem. When I use Drive Image XML to copy "drive to drive". I am getting the following error message:
Hello everyone,
This error is mostly because it won’t be able to copy the drive. They try to copy off the important data and replace it. You can only attempt to recover it but you can’t fix it. Take note: The checkdisk won’t help you instead it could make things worse.
Hope it will help you.
Based on the specification of your e machine (Model T3624) it is equipped with Microsoft Windows XP Home Edition Operating System. Should you need to format your machine or when the operating system needs to renew, you must reinstall operating system manually.
However, we need to consider your machine features. There are machines which do not have recovery or restoration feature. The error you are getting is due to the cloning procedure. Remember in the cloning process, we need to ensure that we are using the same hard drive specifications.
