I am getting problems with VTALARM, help!
The program is receiving a SEGV signal with the debugger and I am not sure why this is happening. What is the chance of having a problem with VTALARM, fork or threads? Also getting error messages like, ‘X’ Library is not founding. What is the meaning of missing ‘RTHooks’? What is the reason for exception rising by the ‘X’ / Network Object application?
Answered By 55 points N/A #100692
First you have to look for any signs of network dis connectivity. If that is the case then fix up your network or Wi-Fi and then try the rest of the subjects.
The second option is to update the program as it is clearly stated that the missing libraries are replaced with new ones when you update your software. So this is best chance to do it.
This is handled through an interrupt. Often there is a task that the interrupt will be called on run time and then it will determine the switching of the threads in between. If for instance a new work around is given then this interrupt is called to handle it and then it produce an output that you can use to determine the results.
Doing this will create multiple forks for you that you can use for any purpose.
