I Am Getting The Error Ps3 Error Code 80010514 Again And Again, None Of The Games Work.
Whenever I try loading any of the games, I receive this error message ps3 error code 80010514. Please help, not even one of my games is working.
Hello, there is a slight chance that the error you are facing is because of your incorrectly installed firmware or your Blu-ray is soon to be dead or already is.
First, as it is a hardware issue you have to try going into the console recovery, this is a risky option but is working for users.
If system switches off, you can try to do the step 2 again.
4. You will be asked to plug in the remote you have via USB and then click on the PS button, so you’ll find yourself on a new screen.
This screen has six options, and you have to select the restore file system option.
Restore File System, it checks for any corrupt files.
Second, you can try cleaning the ps3 thoroughly and if it works, do it regularly.
If both of the above-mentioned solutions don’t work, then contact Sony to replace the unit.
