Hello!
Can you help me fix this problem? I been having hard times using the keypad for my Android phone.I would like to ask if you can give me how to resolve this issue? Can you give me also information what are the components of this phone that affects on its performance and current problem? Can you give me unique resolution where in this phone will have no more issues and will have no more problems in the future. Can you give me the instructions one by one and explain to me each steps why I need to go through that.
I am having difficulties with keyboard in Android phone
You can use any third party keyboard app for your Android for better experience. They provide better performance with customizable themes.
Google Keyboard is one of the best keyboard apps for Android. It’s lightweight, simple and easier to use. It comes with different themes and also, with amazing features like gesture typing etc. Get Google Keyboard.
SwiftKey is another awesome keyboard app with intelligent AI. Its artificial intelligence detects your word usage and is able to offer the correct word that you might want to use. Get SwiftKey Keybaord.
Fleksy Keyboard is the best choice for customizability. You can customize almost all of its features. Get Fleksy Keyboard.
