I am having a printing issue with Bento 4 mac
Hi everyone,
I recently received the Bento 4 mac but I am having a slight problem with I print documents.
When I first printed a document the font size was to small so I adjusted it.
But when I printed another page the writing had not changed.
How do I effectively change it to a standard size?
Answered By points N/A #174574
Hello John,
You are facing the problem because of misconfiguration of your printing option.
When you press “Command+P” or “File >> Print” option, the printing dialogue box will appear. Then, select the printing type as your wish. Before you have printed, don’t forget to click “Preview” whether the shape is perfect or not.
Also, from this page, you will find the printer softwares for your printer in Mac version. They will also help you fix any problem with the printer.
This page will be also very helpful to you.
