I am having problem with Arcsoft webcam companion 2.
I have Arcsoft Webcam Companion 2, when I tried to install it my Skype is having an inverted output on Skype screen.
Basically my Skype screen I’m upside down.
Do you think my application did something wrong with my Skype or my Skype application is having a problem?
Best Answer by James tasnu
Answered By 10 points N/A #144762
Hello Frank Mackeey
Many people having Asus laptop are getting this issue. Visit the following link if you have Asus laptop:
Try uninstalling Arcsoft webcam companion 2 or maybe install version 3 or 4. This might solve your problem.
If nothing works then go to this link
You will be able to flip back your webcam.
Good Luck
Answered By 10 points N/A #144763
Hello Frank,
  • To resolve that issue, you will need open Skype and then go to Tools.
  • Choose Options and then choose Video Settings, followed by WebCam Settings.
  • After that you will need to install manycam, and then open your asus cam in manycam, and after that open manycam in skype.
Here is the procedure you will use for manycam.
  • You will need to start manycam, and then go to sources, and then choose cameras.
  • You will need to choose your camdriver, and then click the icon for vertical flip right of your self image.
  • After that you can start Skype go to: tools > options > general > video settings > and then choose webcam.
  • And then choose "manycam virtual webcam" and the Save.
Carl
