darleen
Posted on - 09/15/2011
How do you do,
I have been trying to build my DVD from my digital video recorder by converting mpeg file in my computer to DVD using Adobe Encore DVD software which I had installed so as to come up with a more personal DVD creating experience. However, when I get to the step of “Build DVD”, the below error message occurs. What could have gone wrong?
Adobe Encore DVD
Sorry, an abnormal condition has been detected. Before quitting, you have one chance to safe your project (don’t use the same name as the original).
Thanks a lot.
amannan
I am having a problem building DVD
Hay.
i have the same problem before. so i have a solution
Do you have video flash player 9.6.03/ 10.1/ 10.03. if you have ten it must be as you want. if don't please install it.
video encore must be registered don't take any demo or free trial version which kind of i used and taken same problem.
all settings>>change into Mpeg/ Avi file to DVD and audio in good level. resolutions in good in setting. keep run ratio 16:09 or 14:0.
I think you have got solution.
Need enough space to your drive so you can save. Windows7 is best performer for install the programs. make default settings in your Windows drive in video Encore.
