Hallo Guys!
I have been scratching my head trying to figure out what could be wrong with my application. I have Arclab Watermark studio 2.11 which I have been using for some time now. It has refused to work giving errors whenever I try to create watermark on any file. Carrying out updates have not been able to work. What can I do to resolve this?
I am having problems creating Arclab watermark on files.
Hello Hanley,
It looks like you are having a problem with Arclab watermark. You have not mentioned which operating system you are currently using. The problem could be your operating system and the version of Arclab is not compatible. That is why your program is not working. You can try to get a new version of Arclab which is compatible with your operating system or you can try using other watermarking software. I have a link for you
https://www.watermark-image.com/
I hope this helps.
